how to block ping from outside
We have a PIX 515. what's the command to block outside poeple ping public ip?
Thanks.
Re: how to block ping from outside
you will have to modify your inbound access-list by adding a line like this:
access-list acl_name deny icmp any any
Kind Regards,
Tom
Tom,
thanks. I will try that coming monday.
Happy new year!
bob
by default it should deny pings
if you can ping it, check the access-list applied to outside interface
there should be a statement something like this:
access-list acl_outside per icmp any any
or
access-list acl_outside per icmp any OUTSIDE_IP_ADDR
if not, there could be a conduit statement, removing this statement may affect other ping capabilities, but is probably wise.
sorry, forgot to say:
if you add a deny icmp statement to the access-list, it will be placed at the end and will never be reached, if there is a permit statement eariler in the list then a match will be found before the end statement.
enter 'no acl_outside permit icmp any any'
or match whatever the statement is that is allowing the ping - place 'no' infront.
thanks. will try that and let you know.
happy new year!
bob
We don't have any access-list acl_outside per icmp any any. We do have conduit permit icmp any any. should we delete this line (no conduit permit icmp any any). Thnak you.
To deny icmp to the outside interface you will need to do the following:
icmp deny any outside
the access-lists and conduits will take care of the hosts that traverse thru the firewall, but not the interfaces themselves. Hope this helps.
532
