Gold
How to cancel pending changes in CSA MC???
I have a couple rule changes I no longer wish to generate. How do I delete/cancel them??
TIA
1 REPLY
Blue
Re: How to cancel pending changes in CSA MC???
If you know the changes made, create the exact opposite change. If you created a rule, delete the rule. If you changed a rule, change it back. Then generate your rules and nothing should change.
That's the only easy way I know of to"cancel" a change. You cannot actually cancel the changes once made. You must make another change to change it back.
Tom S
181
