How to change the interface for the "interface traffic usage" graph in ASDM
I have an ASA 5510 and have recently added a second (primary) internet connection and have an older DSL line which I now intend to use as a backup connection. Planning ahead for this, I put the DSL on interface 0/1 and the T1s are on 0/0. Unfortunately, the handy graph on the home page of ASDM is locked to the "DSL-Outside" interface (0/1) and I can't seem to find any way to change it to the "T1-Outside" interface (0/0). Is there any way to do this? (perhaps a command-line incantation?)
1 ACCEPTED SOLUTION
Re: How to change the interface for the "interface traffic usage
It depends on the security level of the interface. The graph will show the interface with the lowest level. If there are 2 interfaces with the same security level then it will go alphabetically.
Please rate if this helps.
Worked great - thanks!
174
