03-01-2006 05:16 PM - edited 02-21-2020 12:44 AM
i have pix 7.0 .there are pptp server and pptp client on the two side of pix
.i know pix 7.0 doesn't support pptp.but if it's also can't let pptp throughtout? how to config pix 7.0 to permit pptp connection through pix.
thank you very much.
03-01-2006 05:27 PM
Just configure your firewall to permit tcp/1723. That will allow PPTP through.
Hope that helps - pls rate the post if it does.
Paresh
03-01-2006 08:16 PM
if the client is making a pptp conection from inside to the outside, place a permit gre statement in the ouitside interface acl to allow the connection to establish.
03-07-2006 05:10 AM
If the ACls dont fix the issue, try this.
policy-map global_policy
class inspection_default
inspect pptp
service-policy global_policy global
This is eqalent to the old 'Fixup protocol PPTP'
Please rate if this help you to fix the issue.
