How to configure a large number of Cisco devices
Hi netpro,
I've the problem that I've to configure al large numer of Cisco devices (>100). I decided to write a perl-script that reconfigures a template config for all the routers.
That works fine so far, but I've to insert a router specific certificate with
crypto pki import ICW_CA pkcs12 .... passwort
The idea I had was:
create the config with the perlscript, within the perlscript open a telnet session, copy the config into the startup-config an reload the router.
The problem is: How I get the certificate in the correct format to insert it into the startup config, or is there another way to get it into the cert-store?
thank you
n
161
