10-24-2005 08:34 AM - edited 02-21-2020 02:03 PM
Hi all, read subj. It's possible to do for users not managed by VPN concentrator? May be some registry entry?
thank you.
10-24-2005 03:49 PM
In the vpnclient.ini file in th emain install directory there's a section as follows:
[GUI]
AdvancedView=0
If this setting is 0 then the GUI is in imple Mode, 1 = Advanced Mode. With this, and any other setting in any of the .ini files, if you add an exclamation mark to the start of the line that greys out the option via the GUI. So manually edit this file so it looks like:
[GUI]
!AdvancedView=0
Then run th eGUI and it'll start in Simple Mode, and the menu option for Advanced mode will be greyed out. You can automate the initial settings in this file upon installation by following the instructions here:
http://www.cisco.com/univercd/cc/td/doc/product/vpn/client/rel4_0/admin_gd/vcach2.htm
Of course a smart user can edit this file, remove the exclamation mark, rerun the GUI and go into Advanced Mode, but it'll stop 99.99% of users.
10-24-2005 11:45 PM
thank you.
10-25-2005 04:46 AM
deleted post
