Community Member
How to Disconnect a established VPN connection
I Have VPN 3005 used for remote login and LAN to LAN IPSEC conectivity which are working fine . But the problem is , I cannot forcefully disconnect any established VPN connections.
Please sugegst how to disconnect an established VPN conenction.
Thanks for your help in advance.
Bronze
Re: How to Disconnect a established VPN connection
Please let us know the concentrator/client, and any logs for the event.
Thx
Afaq
Community Member
I rebooted the Concentrator 3005 ver 3.5 and re-established the LAN to LAN connectivity. Now we can disconnect the established VPN Connectivity.
Thanks ,
Raj
Community Member
I was wondering how you configured the 3005 to work in a LAN-to-LAN and Remote Access configuration currently? I tried but it would only work in one mode or the other. Not both.
Community Member
To be brief, I have created LAN to LAN under system -> Tunneling protocol ->IPSEC LAN to LAN. And for Remote Access users i created using system ->
User management ->groups and users.
I will try to find link on the cisco and pass it on to you, If you need.
Raj
Community Member
Thanks, I would appreciate that.
261
