Community Member
How to hide WebVPN toolbar
Whenever the webvpn user access the web page which has top frame, the webpage always prompts "A Runtime Error has occurred.", the erros means the object can't support the attribute or method, when I debug it, the web editior highlights "webvpn_show_frame_toolbar()".
How can I avoid this problem?
Thanks!
1 REPLY
Silver
Re: How to hide WebVPN toolbar
This is another symptom that tends to raise suspicions of malware.
In Internet Explorer, on the Tools menu, click Internet Options, and then click the Advanced tab.
Make sure that Disable Script Debugging (Internet Explorer) and Disable Script Debugging (Other) are both enabled. Make sure that Disable a Notification about ever script error is disabled.
133
