05-27-2002 06:03 PM - edited 02-21-2020 11:46 AM
Hi,here're the actual requirements:
1.There're 2 sites leave apart:siteA and siteB.They connecte to ISP respectively.
2.siteA needs access siteB's LAN rescources via VPN connection,not vice versa.
3.The network diagram is like:siteA--->PIX515--->Router----->Internet<------Router<---PIX515<---siteB
4.Expected outcome:PCs/Servers at siteA can access siteB's Servers/PCs any services, "Ping" is explicitly OK
So far,I dont found any docs at CISCO to support my practice.Thank you in advance.
iamsong
06-20-2002 12:35 PM
It doesn't seem this will be possible, as the return traffic needs to be allowed too and you will not be able to distinguish between the return traffic and initiated traffic, So I guess it has to be both ways then.
Thanks and Regards,
Aamir Waheed,
Cisco Systems, Inc.
CCIE#8933
06-23-2002 01:35 AM
You might want to consider IOS Firewall (CBAC) implementation on the router sitting outside siteA. What will happen is, when traffic behind siteA will initiate to go to siteB, the return traffic will be allowed and ACL will dynamically open holes, but when siteB tries to come in, the ACL on ingress interface on the router will deny it.
Here's a sample config
http://www.cisco.com/warp/customer/110/32.html
http://www.cisco.com/warp/customer/110/36.html
http://www.cisco.com/univercd/cc/td/doc/product/software/ios113ed/113t/113t_3/firewall.htm
R/Yusuf
