How to implement XP Cisco VPN client. Please help!!!
dalmada
I am trying to configure remote access for XP desktops using CVPN client software and a Cisco 805 router with IOS IPSec capable( authentication should be local). The remote desktops are behind adsl router wich does nat translations but allow IPSes passthrough.
I have configured it but does not working.
Can you please help me?
Thanks in advance
David
5220
Level 4
Level 4
Hi David,
Check the link:
http://www.cisco.com/en/US/products/sw/secursw/ps2308/prod_configuration_examples_list.html#anchor6
You'll find loads of configuration examples for your scenario.
Please rate if this helped.
Daniel
Hi Daniel,
Thnk you, I tried some examples listed but still not working. The pool of address that I will assign the clients with should be public (internet)addresses?
David
