12-04-2006 06:26 AM - edited 03-09-2019 04:59 PM
We have a 'good' working vpn connection for the company for several time.
But when you have to use direct communication from one connected client to another, it doesn't work.
Is there a simple manner to get this working?
Solved! Go to Solution.
12-04-2006 10:12 PM
Hi Gaston
Can you tell me about the security device which you are using over there as your VPN Server ?
regds
12-04-2006 10:12 PM
Hi Gaston
regds
12-05-2006 02:23 AM
Hi Spremkumar,
thank you for asking.
The cisco devices we use for vpn are:
VPN3000 concentrators
The clients connected to the vpn concentrator can perfectly connect to our internal network.
But the clients can't communicate to each other for direct connections.
I'm not sure what to configure in the VPN concentrator to get this working.
12-05-2006 12:04 PM
Hi Gaston there is something called Reverse Route Injection (RRI)and is used for comunciate sites or host VPN clients, here is the link in Cisco Web Site
I hope it helps
Please rate if is posible
12-07-2006 07:37 AM
Hi J.altami01,
thank you for your reaction.
I saw also this RRI called:
"Client reverse route injection"
But when I enable this, it doesn't make any difference.
12-08-2006 04:57 AM
I'm going to ask Cisco for Help, when I know the sollution I will post it. Any help from the forum is helpfull.
Gaston Bougie
12-08-2006 07:49 AM
The sollution for me was a wrong IP address in the tunnel-default-gateway.
I've removed this with entering 0.0.0.0 and it works now.
Also I've found out that the tunnel default gateway can not be the same as a interface address of the concentrator. I had one interface disabled with IP address 0.0.0.0. This disabled interface prevented me from entering 0.0.0.0 as tunnel-default-gateway.
So I had to put an fictive IP address first on that disabled interface.
