How to open specific port
I have a request from a user to open port 1494. Our pix has conduit commands. The inside network is 10.1.0.0 - specifically 10.1.16.0. What conduit command would I need to use?
1 REPLY
Re: How to open specific port
All depends on exactly what you are trying to do.
If you want to open that port on all hosts on the network, use:
conduit permit tcp any eq 1494 any
If you want to open the port for a specific IP (I.e. you have a STATIC entry in the PIX for the live IP, then use:
conduit permit tcp host [the live IP goes here] eq 1494 any
Hope this helps,
Hans
157
