How to ping NATed ip from inside network
somnath21
I have ASA 5520.In that some of my inside server is nated with public IP address.But I am unable to ping the nated ip (public ip)from inside network. what configuration I have to do for that?
I have one inbound access-lis in the outside interfcae.
How shall I able to ping nated ip address from inside?Please guide in this regard..
Thanx,
som
rod.blackie
Do you mean you have a public IP which is nated to an private address on your server which is located on your inside network?
acomiskey
Level 10
Level 10
This would work...
same-security-traffic permit intra-interface
global (inside) 1 interface
nat (inside) 1 0 0
static (inside,inside) netmask 255.255.255.255
Thanks for your response.I have configured the same but it is not working.
nat (inside) 1 0 0
static (inside,outside) x.x.x.51 10.184.72.23 netmask 255.255.255.255
please reply..
your static nat is wrong, please see carefully Adam's reply static (inside,inside) netmask 255.255.255.255
Jorge Rodriguez
