How to run VPN client between 2 interfaces (i.e. DMZ1 and DMZ2).
djkim
Can anyone pls advise how to config VPN remote access between DMZ1 and DMZ2 on PIX515?
The scenario is as below:
DMZ1 is higher security than DMZ 2 and I would like to have users on DMZ2 must use VPN client to access a terminal server on DMZ1 LAN. I have tried it in many different way, it desn't seem to work.
Am I trying what it is not designed for??? Pls help. Regards, DJ
mostiguy
Level 6
Level 6
The reason you don't see many configurations for that is because not many people use IPSec on LANs. Why do you want to go the vpn route - for authentication, encryption or both?
Anyhow, you might be able to work up a vpn configuration where you use "isakmp enable dmz2" - have a vpn setup on that interface. I can't think of any particular reason why your setup would not work.
The reason I need this is for authentication purpose, two different company is divided by PIX515 and we want users on DMZ2 must authenticate thru vpn client to access allocated source on DMZ1. I have tried with VPN Wizard via PDM, not manually. I believe "isakmp enable dmz2" is set. I didn't have any issue with OUTSIDE interface. I got one question that I would like to confirm, when DMZ2 uses vpn client what ip address would be access point for athentication? I assume this vpn server ip address would be DMZ2 interface ip address, not the DMZ1 interface ip address. Can you pls confirm this ? Thanks DJ
Sounds like an interesting setup. Yes, I would think that DMZ2's IP would be the one you would be attempting to connect to
It didn't work. I am in doubt whether this is really going to work.. I wonder anyone tried out. Thks DJ
