How to setup dynamic routing between a Router 1721 and CVPN3030
I have a Router 1721 connected via Internet to the Concentrator 3030 using 3DES. This connection works fine. For backup I want to use ISDN. To use "Backup Interface" at the Router 1721 is not possible because the routers ethernet interface dont't goes down, if the Internetconnection is broken. So I want to use "Dialer Watch". In this case I need a dynamic routing between the router and the concentrator. Is it possible and if yes how to setup a dynamic routing?
Re: How to setup dynamic routing between a Router 1721 and CVPN3
Do refer this link in which configuring OSPF on the concentrator is being discussed..
http://cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a0080094048.shtml
regds
Thanks, but this dicussion is on the privat side of the concentrator. I need it on the public side, via a the tunnel.
regds
237
