How to use NAT and PAT together in Cisco IOS
We have /29 routable address space for LAN . We have more than 75 local machines which will be Nat'ed on the router .We were thinking to use first 7 routable IP address on dynamic NAT pool and use remaining one IP for PAT overload. When ., I defined two IP nat inside source command , one with dynamic Nat pool and other with PAT overload . In whaterver order I enter , the router always uses PAT but never uses NAT dynamic pool.
Can anyone suggest me how to configure the router to use both NAT and PAT
  • Other Security Subjects
1 REPLY
Re: How to use NAT and PAT together in Cisco IOS
Just use one dynamic NAT pool with overload at the end. What will happen is it will use all the addresses in the pool until it reaches the last one, which will then be used for PAT.
R/Yusuf
345
