How to view 3DES encryption key on a Cisco
How can you Display the secret shared key in a router ???
is it possible.
regards per
Re: How to view 3DES encryption key on a Cisco
Do you mean the ISAKMP key? That's displayed in clear -text in a router configuration. In a PIX it is displayed as ********, and no, there's no way to view it.
If I'm way off base here please elaborate on what you mean.
I'm no reffering to the Preshare key ,
I'm reffering to the encryption key
I'm Currently in Tunisia running a CSIDS course.
Down here the Goverment needs the Encryption key before the can use encryption ?????, bit of a Problem..
And anyway you would get new encryption keys every time you re-establish the SA's , wouldnt you
regards
per
270
