HTTP management restricted by named ACL?
There's probably an easy solution to this. I know that I can enable the http service on a switch and limit who can use http to manage the switch with the "ip http access-class x" command. The variable 'x' in this case is a numbered, standard access list (1-99). What if I want to accomplish the same thing but by using named access lists?
Sincerely,
Jeff
1 REPLY
Re: HTTP management restricted by named ACL?
router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
router(config)#ip http access-class ?
<1-99> Access list number
If your output is similar to that above, this would suggest that a numbered ACL is your only option (i.e.: a named ACL is not supported).
99
