Hub and spoke design for router to router VPN circuits
Can my hub router have two different pre-shared keys to support each spoke router, or does the hub router and two spoke routers need to use the same pre-shared key. An example is as follows:
Hub router crypto isakmp key xxxx123 address 10.10.10.10
crypto isakmp key 123xxxx address 20.20.20.20
Spoke router 1 crypto isakmp key xxxx123 address 11.11.11.11
Spoke router 2 crypto isakmp key 123xxxx address 21.21.21.21
or
crypto isakmp key xxxx123 address 20.20.20.20
Spoke router 2 crypto isakmp key xxxx123 address 21.21.21.21
Does anyone have any thoughts on this scenerio
Re: Hub and spoke design for router to router VPN circuits
Good question. I had the same thought. Your first scenario will work and is best. SInce each pre-shared key is tied to an IP address, for security sake, it is always best to use a unique key between each hub and spoke. I am currently running three spokes from my hub with three different pre-shared keys. It works fine.
RJ
Thanks for your feed back RJ. It will help in deploying this solution in a hub and spoke design
310
