hub-spokes routing between spokes
I have hub-spoke VPN configuration. At hub I have 2611 XM and at spokes 1721. VPN works fine between hub and spoke. I need connection between spokes through a hub. Is it possible routing between spokes through the hub with static routes and how can I do that? What is my default gateway for a spoke for network on the other spoke? Do I use public or private address for routing? What are my static routes on the hub?
I have NAT on all routers because they give Internet access.
I need better example than this article “Cisco ? Configuring IPSec Router?to?Router Hub and Spoke with Communication Between the Spokes” from Cisco site. It wasn’t helping me.
Silver
Re: hub-spokes routing between spokes
You could try Static Mapping in the Hubs. You need to establish a tunnel between the spokes in order to have the RIP routing working. With OSPF there shouldn't be such a problem.
We use DMVPN, NHRP, and EIGRP/OSPF for a dynamic spoke to spoke solution. Essentially w/ NHRP the Hub keeps a database of all the spoke physical and tunnel IPs. So when the tunnels are first established to the hub it tells all subsequent pkts that they don't have to come to hub to talk to other spokes, but that they can establish tunnels to other spokes w/o going through the hub for spoke to spoke communication.
The DMVPN allows for ease of tunnel configuration, so when you add another spoke you don't have to modfiy all the other spokes.
Here is my problem:
I have more than three sites in VPN network: Central office SITE A, remote offices SITE B, SITE C, SITE D and remote dialup users with CVPC. I can establish VPN between SITE B,C,D and SITE A. I can ping from SITE A all private network on SITE B,C,D.Also I have to ping from Site B networks on site C,D but I CANNOT do it. I put static routes, access-lists but it doesn't work.
Also remote clients can connect to site B by CVPC but they cannot connect to site A.
SITE A
version 12.3
no service pad
hostname xxxxxx
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
username xxxx privilege 15 password 0 xxxxx
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
ip subnet-zero
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 1
hash md5
authentication pre-share
crypto isakmp policy 3
encr 3des
group 2
crypto isakmp policy 5
hash md5
crypto isakmp key xxxxxx address 212.39.103.154 no-xauth
crypto isakmp key xxxxxx address 80.65.95.162 no-xauth
crypto isakmp key xxxxxx address xxxxxxx no-xauth
crypto isakmp key xxxxxx address 0.0.0.0 0.0.0.0 no-xauth
crypto isakmp client configuration group xxxxx
key xxxxxx
dns 192.168.1.100
domain cpn.vwg
pool ippool
crypto isakmp profile VPNclient
description VPN clients profile
match identity group xxxxxx
client authentication list userauthen
isakmp authorization list groupauthor
client configuration address respond
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto ipsec transform-set myset1 esp-des esp-md5-hmac
crypto ipsec transform-set myset3 esp-des esp-md5-hmac
crypto ipsec transform-set rtpset esp-des esp-md5-hmac
crypto ipsec transform-set myset4 esp-des esp-md5-hmac
crypto ipsec transform-set myset5 esp-des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set myset
set isakmp-profile VPNclient
crypto dynamic-map rtpmap 11
set transform-set rtpset
match address 118
crypto map clientmap 5 ipsec-isakmp
set peer 212.39.103.154
set transform-set myset1
match address 115
crypto map clientmap 7 ipsec-isakmp
set peer 80.65.95.162
set transform-set myset3
match address 117
crypto map clientmap 8 ipsec-isakmp
set peer xxxxxx
set transform-set myset4
match address 119
crypto map clientmap 9 ipsec-isakmp
set peer xxxxxx
set transform-set myset5
match address 120
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
crypto map clientmap 11 ipsec-isakmp dynamic rtpmap
no voice hpi capture buffer
no voice hpi capture destination
interface Null0
no ip unreachables
interface FastEthernet0/0
description $FW_INSIDE$
no ip unreachables
ip nat inside
no ip mroute-cache
speed auto
half-duplex
no cdp enable
interface FastEthernet0/1
description $FW_OUTSIDE$
ip address 195.222.36.202 255.255.255.252
no ip unreachables
ip nat outside
no ip mroute-cache
duplex auto
speed auto
no cdp enable
ip local pool ippool 192.168.200.1 192.168.200.254
ip nat inside source route-map nonat interface FastEthernet0/1 overload
ip http server
ip http authentication local
ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 195.222.36.201
ip route 10.112.192.0 255.255.192.0 192.168.1.101
ip route 192.168.0.0 255.255.255.0 212.39.103.154
ip route 192.168.11.0 255.255.255.0 xxxxxxxx
ip route 192.168.13.0 255.255.255.0 FastEthernet0/1
ip route 192.168.14.0 255.255.255.0 xxxxxxxx
ip route 192.168.15.0 255.255.255.0 FastEthernet0/1
ip route 192.168.220.0 255.255.255.0 xxxxxxx
ip route 193.77.75.0 255.255.255.0 80.65.95.162
ip access-list extended addr-pool
ip access-list extended default-domain
ip access-list extended dns-servers
ip access-list extended idletime
ip access-list extended inacl
ip access-list extended key-exchange
ip access-list extended protocol
ip access-list extended service
ip access-list extended timeout
ip access-list extended tunnel-password
access-list 101 remark SDM_ACL Category=18
access-list 101 deny ip 192.168.11.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 101 deny ip 193.77.75.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 deny ip 10.112.192.0 0.0.31.255 192.168.0.0 0.0.0.255
access-list 101 deny ip 192.168.15.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 101 deny ip 192.168.14.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 101 deny ip 192.168.13.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 101 deny ip 10.112.192.0 0.0.31.255 193.77.75.0 0.0.0.255
access-list 101 deny ip 193.77.75.0 0.0.0.255 192.168.14.0 0.0.0.255
access-list 101 deny ip 10.112.192.0 0.0.31.255 192.168.14.0 0.0.0.255
access-list 101 deny ip 193.77.75.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 101 deny ip 10.112.192.0 0.0.31.255 192.168.11.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.13.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.14.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.220.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 115 remark SDM_ACL Category=20
access-list 115 permit ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 10.112.192.0 0.0.31.255 192.168.0.0 0.0.0.255
access-list 115 permit ip 193.77.75.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 117 remark SDM_ACL Category=20
access-list 117 permit ip 192.168.1.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 117 permit ip 10.112.192.0 0.0.31.255 193.77.75.0 0.0.0.255
access-list 117 permit ip 192.168.0.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 117 permit ip 192.168.1.0 0.0.0.255 192.168.220.0 0.0.0.255
access-list 117 permit ip 192.168.13.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 117 permit ip 192.168.14.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 117 permit ip 192.168.15.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 117 permit ip 192.168.11.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 118 remark SDM_ACL Category=20
access-list 118 permit ip 10.112.192.0 0.0.31.255 192.168.13.0 0.0.0.255
access-list 118 permit ip 192.168.1.0 0.0.0.255 192.168.13.0 0.0.0.255
access-list 118 permit ip 193.77.75.0 0.0.0.255 192.168.13.0 0.0.0.255
access-list 118 permit ip 10.112.192.0 0.0.31.255 192.168.15.0 0.0.0.255
access-list 118 permit ip 192.168.1.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 118 permit ip 193.77.75.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 119 permit ip 192.168.1.0 0.0.0.255 192.168.14.0 0.0.0.255
access-list 119 permit ip 10.112.192.0 0.0.31.255 192.168.14.0 0.0.0.255
access-list 119 permit ip 193.77.75.0 0.0.0.255 192.168.14.0 0.0.0.255
access-list 120 permit ip 192.168.1.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 120 permit ip 10.112.192.0 0.0.31.255 192.168.11.0 0.0.0.255
access-list 120 permit ip 193.77.75.0 0.0.0.255 192.168.11.0 0.0.0.255
no cdp run
route-map nonat permit 10
match ip address 101
dial-peer cor custom
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
line aux 0
line vty 0 4
privilege level 15
password xxxxx
transport input telnet ssh
end
SITE B
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname xxxxx
boot-start-marker
boot-end-marker
logging buffered 52000 debugging
logging console critical
username xxxxx privilege 15 password 7 xxxxxxxxxxx
aaa new-model
ip subnet-zero
no ip source-route
ip tcp synwait-time 10
ip domain name net.com
no ip bootp server
ip cef
ip audit notify log
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
hash md5
crypto isakmp policy 10
encr 3des
group 2
crypto isakmp key xxxxxx address 195.222.36.202
key xxxxx
dns 193.77.75.234
pool ipadrese
mode transport
crypto dynamic-map dynmap 5
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to 195.222.36.202
set peer 195.222.36.202
match address 101
crypto map SDM_CMAP_1 10 ipsec-isakmp dynamic dynmap
crypto map SDM_CMAP_1 11 ipsec-isakmp
description Tunnel to xxxxx
set peer xxxxx
match address 102
description $FW_INSIDE$$ETH-LAN$
ip address 193.77.75.253 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
speed auto
no cdp enable
interface Serial0
ip address 80.65.95.162 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
no cdp enable
ip local pool ipadrese 192.168.220.1 192.168.220.254
ip nat inside source route-map SDM_RMAP_1 interface Serial0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 80.65.95.161
ip route 10.112.192.0 255.255.224.0 192.168.1.101
ip route 192.168.0.0 255.255.255.0 192.168.1.1
ip route 192.168.13.0 255.255.255.0 192.168.1.1
ip route 192.168.14.0 255.255.255.0 192.168.1.1
ip route 192.168.100.0 255.255.255.0 Serial0
ip route 192.168.220.0 255.255.255.0 Serial0
ip http server
ip access-list extended ios_web_exec
logging trap debugging
access-list 100 remark SDM_ACL Category=2
access-list 100 deny ip 193.77.75.0 0.0.0.255 192.168.220.0 0.0.0.255
access-list 100 remark IPSec Rule
access-list 100 deny ip 193.77.75.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 100 deny ip 193.77.75.0 0.0.0.255 192.168.14.0 0.0.0.255
access-list 100 deny ip 193.77.75.0 0.0.0.255 192.168.13.0 0.0.0.255
access-list 100 deny ip 193.77.75.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 deny ip 193.77.75.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 100 deny ip 193.77.75.0 0.0.0.255 10.112.192.0 0.0.31.255
access-list 100 permit ip 193.77.75.0 0.0.0.255 any
access-list 101 remark SDM_ACL Category=4
access-list 101 permit ip 193.77.75.0 0.0.0.255 10.112.192.0 0.0.31.255
access-list 101 permit ip 193.77.75.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 remark IPSec Rule
access-list 101 permit ip 193.77.75.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 permit ip 193.77.75.0 0.0.0.255 192.168.13.0 0.0.0.255
access-list 101 permit ip 193.77.75.0 0.0.0.255 192.168.14.0 0.0.0.255
access-list 101 permit ip 192.168.220.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 102 remark SDM_ACL Category=4
access-list 102 remark IPSec Rule
access-list 102 permit ip 193.77.75.0 0.0.0.255 192.168.100.0 0.0.0.255
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 100
^C
line con 0
transport output telnet
line aux 0
line vty 0 4
privilege level 15
line vty 5 15
privilege level 15
scheduler allocate 4000 1000
scheduler interval 500
end
SITE C
version 12.3
hostname xxxxx
memory-size iomem 25
no aaa new-model
ip subnet-zero
ip audit notify log
ip ssh time-out 30
ip ssh authentication-retries 5
ip ssh port 2222 rotary 55
ip ssh rsa keypair-name shex
hash md5
crypto isakmp key 0 xxxx address 195.222.36.202 no-xauth
match address 115
interface Ethernet0
ip address 192.168.0.1 255.255.255.0
ip access-group 150 in
no ip proxy-arp
ip nat inside
half-duplex
hold-queue 100 in
hold-queue 100 out
ip address 212.39.103.154 255.255.255.128
no ip proxy-arp
ip nat outside
speed auto
hold-queue 100 in
hold-queue 100 out
ip nat inside source route-map nonat interface FastEthernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 212.39.103.130
ip route 192.168.1.0 255.255.255.0 195.222.36.202
ip route 193.77.75.0 255.255.255.0 192.168.1.1
no ip http server
no ip http secure-server
access-list 110 deny ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 110 deny ip 192.168.0.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 110 deny ip 192.168.0.0 0.0.0.255 10.112.192.0 0.0.31.255
access-list 110 permit ip 192.168.0.0 0.0.0.255 any
access-list 115 permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 115 permit ip 192.168.0.0 0.0.0.255 10.112.192.0 0.0.31.255
access-list 115 permit ip 192.168.0.0 0.0.0.255 193.77.75.0 0.0.0.255
access-list 150 deny icmp any any echo
access-list 150 permit ip any any
no cdp advertise-v2
match ip address 110
line con 0
line aux 0
line vty 0 4
password 7 xxxxxx
login local
no scheduler allocate
end
Can you help me with the configuratio which I post it?
If you have only one subnet per site, protected by hub router try EazyVPN. Configuration is very easy and scalable, even TAC say it is hard to trobleshot EasyVPN with router, I had no problems!
305
