hummingbird
Dear sir :
i have the following problem:
i have two servers one in the DMZ and the another in the LAN the two servers have a hummingbird (hcs) application service , when the DMZ server need to connect to LAN server using trust authentication using port 8765 it gives no response and for your knowledgement i open this port from DMZ to LAN, can u help me.
regards
1 REPLY
Bronze
Re: hummingbird
Please give more information... Are you using NAT? If so, is your DMZ server pointing to the REAL address of the inside server, or the NAT address? Is there a translation for the Inside server into the DMZ. If you are not using NAT, do you have a NAT (0) or a static acl for the networks? What version are you on? What platform? (501, 515, 535, etc)
Look at the log files, are you seeing any 'deny' statements when you attempt to connect?
205
