I am stuck with setting up VPN
I am newby with setting up a router. Right now I was able to set up the router including firewall.
The only problem I have now is that I need to set up VPN.
The VPN is just used for 4 people which need to access the company's network through the internet. I was reading docs for docs and also found some sample configurations. But until now, I still did not check how it works at the end.
The nicest way for me would be if I can define some users in the router which then are allowed to go through the firewall.
We have a Cisco2600 runing IOS 12.1.
I saw some example with the command crypto. But I also cannot find this command. So, how could I set up something towards this?
Any tips or hints would be great.
Re: I am stuck with setting up VPN
This link should help.
You might have to upgrade to the right feature set to run encryption on your router.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800949db.shtml
Remote users (mobile users) will have to use VPN Client too.
Thanks for your answer. I was running into this document to already. In this document it is written that the requirements are
- Cisco IOS® Software Release 12.0.7T or later
- Hardware that supports this software revision
- CiscoSecure VPN Client 1.0/10A or 1.1
On our Cisco 2600 router we are running IOS 12.1. Well this is what I get from show version at the router's command prompt.
IOS (tm) C2600 Software (C2600-IO3-M), Version 12.1(21), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 19-Aug-03 00:29 by kellythw
Image text-base: 0x80008088, data-base: 0x8089BB38
ROM: System Bootstrap, Version 12.2(10r)1, RELEASE SOFTWARE (fc1)
rsag00 uptime is 3 days, 14 hours, 39 minutes
System image file is "flash:c2600-io3-mz.121-21.bin"
cisco 2612 (MPC860) processor (revision 0x00) with 26624K/6144K bytes of memory.
Processor board ID JAE07290X5Z (1233014571)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Token Ring/IEEE 802.5 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
What I understand now is that this should be okay or do I miss something?
I also cannot find the VPN client as well. On the left side on the forum page is a link to the VPN client. But that page cannot be found.
I am quite stuck.
Sorry. The link for the VPN client is on the right side.
The vpn client is a software that you have to download using your CCO login from Cisco Software center. Dont know if you are still having problems with this ??
92
