I installed VPN client and I loss the local LAN connection
when I install VPN client on WIN95 PC I loss the LAN connection. I can't ping, access to sharing resources and printer.
Its not needed up the tunnel by this occur.
This occur randomly.
On Win2K PCs I need down the services CiscoSystem,Inc VPN Services to perform a ftp.
I use VPN Client 3.6.2.
Anyone can help me?
Thanks.
1 REPLY
Re: I installed VPN client and I loss the local LAN connection
Do you have the clients firewall turned on? Visit microsoft.com and get the latest windows patchs. Do you have any other firewall software or antivirus software installed on your pc's? Does local lan access return after unistalling the client? Can you ping anything else besides the LAN when this randomly occurs? Ping your self?
Kurtis Durrett
89
