I need a help for my config in pix 501
I have the configuration bellow : 4 port open with access-list
but when i check the logs i have the message : Deny tcp src outside:x.x.x.x/port number dst inside: y.y.y.y/80 by access-group "101"
x.x.x.x ip outside
y.y.y.y ip inside
this is my config:
PIX Version 6.2(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password BfBD7MtL0Hsmgfmw encrypted
passwd BfBD7MtL0Hsmgfmw encrypted
hostname New-York
domain-name eyouness.net
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 101 permit tcp any host y.y.y.y eq ftp
access-list 101 permit tcp any host y.y.y.y eq www
access-list 101 permit tcp any host y.y.y.y eq ftp-data
access-list 101 permit tcp any host y.y.y.y eq smtp
pager lines 24
logging on
logging trap debugging
logging host inside y.y.y.y
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside y.y.y.y 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface ftp y.y.y.y ftp netmask 255.255.255.255 0 0
static (inside,outside) tcp interface www y.y.y.y www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface smtp y.y.y.y smtp netmask 255.255.255.255 0 0
static (inside,outside) tcp interface ftp-data y.y.y.y ftp-data netmask 255.255.255.255 0 0
access-group 101 in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh timeout 5
dhcpd lease 3600
dhcpd ping_timeout 750
terminal width 80
Cryptochecksum:d4acb12f47d345195e46878f89496b4f
: end
How can i do please
Thanks for your response
1 REPLY
Re: I need a help for my config in pix 501
You need to replace y.y.y.y in the ACL with the address assigned by DHCP. Alternatively, you can use "any" in the ACL if your DHCP address will be changing. Since this is the only address assigned to the PIX, the end result will be the same.
Sincerely,
David.
101
