I need help quickly- PIX 515e ver. 6.3 (5)
I'm new to this Cisco product and I'm in a jam. I've got to get this product up and running by tomorrow morning.
(Problem:) I've got communications running on the inside of the firewall, and with an access-list I can ping the outside world successfully; however, while inside, behind the firewall, I can't see anything through a web browser. It's like the traffic is not getting through. Please help, what do I need to do?
Below is copy of the current configuration:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxxx
hostname pixfirewall
domain-name ciscopix.com
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
object-group service Internet tcp-udp
description Group for Internet access
port-object eq echo
port-object eq www
port-object eq domain
access-list inside_access_in permit icmp interface inside interface outside echo-reply
access-list inside_access_in permit icmp interface inside interface outside time-exceeded
access-list inside_access_in permit icmp interface inside interface outside unreachable
access-list inside_access_in permit tcp any object-group Internet any object-group Internet log
access-list inside_access_in permit tcp any object-group Internet host 208.50.85.161 object-group Internet log
pager lines 24
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside 208.x.x.x.255.255.224
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
pdm location 208.50.x.x.x.255.255 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 10 192.168.1.3-192.168.1.254 netmask 255.255.255.0
global (inside) 1 192.168.1.3-192.168.1.254
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
access-group inside_access_in in interface inside
routing interface outside
ospf authentication null
routing interface inside
route outside 0.0.0.0 0.0.0.0 208.50.85.161 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa proxy-limit disable
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server contact
snmp-server community
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no-xauth no-config-mode
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 inside
dhcpd dns 206.165.6.11 209.130.136.2
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxx
: end
2 ACCEPTED SOLUTIONS
Re: I need help quickly- PIX 515e ver. 6.3 (5)
access-list inside_access_in permit ip any any
Thats my guess.
Im a gui guy, never use the cli. Good luck
Gold
this statement should have a public ip (or a range of public ips), such as 208.50.85.x.
further, i was just wondering what is the purpose of the outbound acl. pix will (by default) forward packet from higher security level (i.e. inside) to lower security level (i.e. outside) providing nat/global/static is configured properly.
Thats my guess.
Gold
To Trinityfruit & Jackko:
Guys, thanks for your help. I got the system up and running. All the bells and whistles came on-line when I entered:
-through the CLI - saved to config, then to flash, and BAM I was seeing the outside world. You rock Trinity!!
Jackko made a good point on the global (outside) IP address, to clean things up, this was also changed to reflect an outside routable IP (pool). The network traffic in and out is fast. It now reads:
global (outside) 100 208.50.85.165-208.50.85.175 netmask 255.255.255.224 (100 being the ID I assigned to the pool)
Jackko your question about the outbound acl - this may have been added for the VPN connection to a host company. I had to cut back a section of the coding because I exceeded the 4000 character limit for the post. (good eye)
Thanks again for all your help.
jc,
If you go to post a config in the future, be sure to remove:
1) Your passwords:
passwd xxxx
2) Your public IP address:
ip address outside 208.50.x.x.x.255.224
With that amount of information, an UNSCRUPULOUS person could hack into your PIX and make changes, getting into your protected network. If you haven't already, I would change your passwords . . .
127
