I think there is a problem with my pix501
Ok, I thought it was just me and I'm starting to think the pix is my problem. Running through setup I get the pix's basic config set up. Now from what I understand and what it shows me access from the inside should now be allowed outside. Upon completion of the boot process this happens. I can get out to the internet and do whatever I like from the inside interface..... for about 5 minutes or so. Then bam, no access. I can't ping anything. from an outside network I can ping the outside interface of the router, but the router itself won't ping anything but inside and it's interfaces. If I do a reload command it will work again for a few minutes. Here is a write term of my config:
User Access Verification
Password:
Type help or '?' for a list of available commands.
pix1> en
Password:
pix1# write term
Building configuration...
: Saved
PIX Version 6.3(1)
interface ethernet0 10baset
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxx
passwd xxxxx
hostname pix1
domain-name mail.marini.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
name 192.168.5.30 NINTWEB
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 24.x.x.x.x.255.248
ip address inside 192.168.5.5 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.5.5 255.255.255.255 inside
pdm location 192.168.5.0 255.255.255.0 inside
pdm location NINTWEB 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 10 interface
global (outside) 1 24.97.9.13
global (inside) 1 24.97.9.13
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 24.97.9.9 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.5.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 60
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 750
terminal width 80
Cryptochecksum:xxxx
: end
[OK]
pix1#
any help would be greatly appreciated.
Silver
Re: I think there is a problem with my pix501
I noted that your outside interface is running at 10mbits half duplex. What devices are the pix interfaces connected to? Insure that no switch or router ports that the pix interfaces connect to are set to auto-negotiate. Both ends should be set the same way and I have seen issues like this arise due to auto-negotiate being set.
The next time this problem happens, console into the pix and do a show interface command. I am curious as to what the status of them are, especially the outside one.
Another thing I noted is that the global (outside 10) interface. Can you change the nat (inside) 10 to nat (inside) 1 to use a different ip address? Or have you tried that already and still had the issue?
Ok, the outside interface was supposed to be 10full so I changed it and the interface. It worked for a bit longer this time, but still froze up. here is a write term with the current config, followed with sh int (note this is the state in which the pix is not allowing internet access):
Password:
pix1> en
Password:
pix1# config t
pix1(config)# write term
: Saved
PIX Version 6.3(1)
interface ethernet0 10full
passwd xxxxx
hostname pix1
names
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
terminal width 80
Cryptochecksum:xxxx
: end
[OK]
pix1(config)# sh int
interface ethernet0 "outside" is up, line protocol is up
Hardware is i82559 ethernet, address is 000f.2497.ddbb
IP address 24.97.9.12, subnet mask 255.255.255.248
MTU 1500 bytes, BW 10000 Kbit full duplex
1408 packets input, 488771 bytes, 0 no buffer
Received 770 broadcasts, 2 runts, 0 giants
80 input errors, 78 CRC, 0 frame, 0 overrun, 78 ignored, 0 abort
837 packets output, 111138 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/2)
output queue (curr/max blocks): hardware (0/3) software (0/1)
interface ethernet1 "inside" is up, line protocol is up
Hardware is i82559 ethernet, address is 000f.2497.ddbc
IP address 192.168.5.5, subnet mask 255.255.255.0
MTU 1500 bytes, BW 100000 Kbit full duplex
24836 packets input, 3941614 bytes, 0 no buffer
Received 22326 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3226 packets output, 3489068 bytes, 0 underruns
input queue (curr/max blocks): hardware (128/128) software (0/30)
output queue (curr/max blocks): hardware (1/46) software (0/1)
pix1(config)#
Silver
I am thinking you have a link layer problem. I noted that the percentage of input errors to input packets on the e0 interface is more than 3%.
Let me know what the pix log and external log, if you are logging to another host, messages say at the time you have the issue.
Try replacing the e0 cable with one that tests clean, if you have a cable tester.
What does the e0/outside interface connect to? Is it a managed switch or hub? If so, look there and see if the port that the pix connects to also is having a high percentage of input and/or output errors.
I have cable internet service. They provided me a brand new 5 port zyxel router. Right now the way my network is set up I have the zyxel piece, going to 3 linksys routers which each output to the same NPI switching gear. Each router has a static IP and they are used for different services.
Right now the pix is plugged into one of the ports on the zyxel and a port on the npi switch. I have a test server set up that I changed the default gateway on to point to the pix. I swapped the cable on the pix to a brand new cable, performed a reload on the pix, and still have the same problem.I also swapped ports on the zyxel with another router and the same problem.
I don't have logging set up. I can't understand why there is a problem,
Silver
The pix's outside interface is connected to zyxwl routerm and the inside interface is conected to the npi switching gear, am I correct in that assumption?
I would setup logging on the pix just to see if you can get some meaningful info when the problem occurs; set the logging level to error.
You mentioned the linksys routers. How do they fix in relation to the pix? Are they running routing protocols such as ospf or rip?
Yes the zyxel is on the pix's outside interface and the npi is on the inside.
I'll try setting up logging later tonight. I'm also going to directly connect my laptop to the pix and unplug it from the npi and see what happens.
I don't think the linksys routers support anything besides of rip. 2 are wireless routers and the 3rd is a standard router, all of which are really home type equipment not meant for business or advanced types of configuration. I'm also getting rid of the npi for a 2621 router and a 2900xl switch, but I've put off on it until I can get this piece working first.
I solved the problem by updating the pix firmware.
old version: 6.3.1
new version: 6.3.3
problems solved. I'm guessing I had a bad flash install or something along those lines.
100
