iChat AV and Pix 501
One of one clients has a dedicated Apple Mac environment with Pix 501 firewall. They use iChat AV for Audio/ Video conferencing. The connection fails everytime a session is started to anyone outside the company.
iChat reports: Tried to send UDP SIP "invite" to the following IP addresses and ports: 192.168.x.x:5060
The following are enabled on the Pix server:
fixup protocol sip 5060
fixup protocol sip udp 5060
I have also added the line:
access-list 100 permit udp any any range 5060 5060
as well as:
access-list 100 permit udp any any range 16384 16403
access-list 100 permit tcp any any range 16384 16403
as outlined in: http://docs.info.apple.com/article.html?artnum=93208
I still get the same problem where a session cannot be initiated. I can provide the conf file if need be, but am I missing out on something obvious here?
Many thanks for any help given.
Jay
1 REPLY
Re: iChat AV and Pix 501
Found the answer:
Even though its bad etiquette, this fix works!
Change the lines:
to
no fixup protocol sip 5060
no fixup protocol sip udp 5060
This will enable the connection for iChat A/V users to made.
-J-
101
