Idle timeout issues after concentrator IOS Upgrade
After a recent IOS upgrade on our concentrator to vpn3005-4.7.2.B-k9.bin to enable the SSL VPN function, we noticed that the clients version 4.6.01.0019 timeout and lose connection when the connection is idle (approx 8mins) regardless of any settings on the concentrator being unchanged (Idle timeout set to 480). However if there is constant traffic the VPN stays up indefinitely
I have tested a new client 4.7.00.0533 which works perfectly with the upgraded version of IOS on the concentrator. As the logistics of addressing all the clients is extensive, is there potential a version of IOS for the concentrator with SSL VPN’s which would be more suited to the version of client (4.6.01.0019)????
1 REPLY
Bronze
Re: Idle timeout issues after concentrator IOS Upgrade
The root cause of the watchdog timeout can be hardware- or software-related. Here are the common symptoms through which you can identify the source of the problem:
If a router that has been properly operational for months suddenly starts to reload every 20 minutes, or if it continuously reboots and you can no longer access it, the problem is most likely a hardware-related issue. This is also the case if a new module has been installed recently, and the router crashes by watchdog timeout afterwards.
If the router starts to crash after a configuration change or a change in the Cisco IOS software version, it is probably a software-related issue.
For more information refer to the following url:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a00800f67db.shtml
94
