Community Member
IDM_Event_Viewer issue
Hi all,
We have 3 sensors which are integrated in an Event viewer software. Previousy two of the devices were giving "failed to open the connection" error. So i deleted and added the devices manually and successfully added.
Now the problem is one of the sensor is not reflecting in the Sensor Name Group. I tried rebooting the device but no success.
details of the IDS machine is given below...
Cisco Intrusion Prevention System, Version 6.0(3)E1
Host:
Realm Keys key1.0
Signature Definition:
Signature Update S312.0 2007-12-17
Virus Update V1.2 2005-11-24
OS Version: 2.4.30-IDS-smp-bigphys
Platform: IDS-4215
Trial license, expires: 14-Mar-2008 UTC
Sensor up-time is 9 min
Using 403976192 out of 502026240 bytes of available memory (80% usage)
system is using 17.8M out of 29.0M bytes of available disk space (61% usage)
application-data is using 31.7M out of 166.8M bytes of available disk space (20%
usage)
boot is using 37.9M out of 68.6M bytes of available disk space (58% usage)
application-log is using 529.1M out of 2.8G bytes of available disk space (20% u
sage)
MainApp N-2007_JUN_19_16_45 (Release) 2007-06-19T17:10:20-0500 Ru
nning
AnalysisEngine N-2007_JUN_19_16_45 (Release) 2007-06-19T17:10:20-0500 Ru
nning
CLI N-2007_JUN_19_16_45 (Release) 2007-06-19T17:10:20-0500
* IPS-sig-S311-req-E1 22:17:22 UTC Tue Dec 11 2007
IPS-sig-S312-req-E1.pkg 05:14:29 UTC Tue Dec 18 2007
Recovery Partition Version 1.1 - 6.0(3)E1
PLEASE SUGGEST ME ON HOW TO ADD THIS INTO THE SENSOR GROUP....
Suggestions are appreciated.
-Rajesh P
110
