IDM Issue
I ran Sysconfig-sensro, then option number (6), then type (Y) when it prompt with [WEB based Inrustion Detection Device Manager (Y/N)?].
then it shows some configuration (which all correct)then I typed (Y)
then Making the IDs Daemon ......... Press Enter to continue .
Then it shows the following NOTE:
** This script does not tell the IDS Manager how to comunicate with the Sensor. Consult the User's Guid for information about how to add a new sensor machiene to an existing IDS Manager configuration.**
Also, I ran these command [netstat -a] to check if the port 443 enable or not, but what I found is only (FTP, Telnet and 22) there is no 443 at all.
any other Ideas!!!
thank you
  • Other Security Subjects
Re: IDM Issue
It sounds like you are not logging in as root, telnet to the sensor and login as netrangr, type "su -" and enter your root password, then go through the steps above. Let me know if you have anymore problems.
Re: IDM Issue
lwierenga,
I think I was a ROOT, also you can NOT access or run the command (Sysconfig-sensor) as netrangr...
thank you
83
