07-15-2003 03:56 AM - edited 03-09-2019 04:02 AM
Is there going to be any comprehensive documentation released on version 4.0 of the IDS sensor?
The is no documentation on this new RDEP protocol or the architecture of the device. Quite honestly, the documentation is really shoddy for version 4.0.
Quite dissapointing.
07-15-2003 12:23 PM
See if this helps you.
http://www.cisco.com/cgi-bin/dev_support/access_level/product_support?pcgi=1&product=IDS_INT_API
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/index.htm
Yatin
yatin
07-17-2003 12:13 AM
I stand corrected.
07-17-2003 01:09 PM
I can't find documentation on IDIOM, which is an XML message format referenced in the Cisco IDS RDEP API document. Any help?
07-18-2003 09:56 AM
The IDIOM specification is still going through review and the final copy is not yet ready for posting.
You can try contacting your Cisco representative and requesting a draft copy of the specification.
07-18-2003 08:04 AM
You will find the RDEP protocol specification at:
Jeff
