Community Member
IDS and CSPM 2.3i
I am trying to configure the IDS 4210 with CSPM 2.3i. I try to add the sensor using the wizard and choose the "verify IP address". The CSPM says that it is unable to communicate with the sensor. I checked my sysconfig-sensor settings and am able ping the CSPM host server from the sensor and vice-versa. Any ideas?
1 REPLY
Community Member
Re: IDS and CSPM 2.3i
Make sure all you POP protocol settings are correct between the sensor and CSPM.
Sensor host ID, Sensor organization ID, IDS Manager host ID,Manager organization ID etc
87
