IDS and SQL Injection
Hi all,
My Web server is IIS 5.0.
I have IDS 4235.
So my question is:
1. Is IDS can detects and protects again SSL encripted sessions (HTTPS).
2. How IDS can detects SQL injection in encripted sessions.
Pls, help
1 REPLY
Re: IDS and SQL Injection
The IDS can not do much with encrypted traffic except understand a few protocol violations. For the IDS to understand see the traffic you might want to use a SSL accelerator and have the IDS behind that. Another option you may want to consider is HIDS. Since the IDS CAN NOT understand the encrypted traffic it is blind to SQL injection / insertion techniques. These are not always done over SSL so some signatures may catch minor stuff. The majority, however, should be over SSL. Once again HIDS probably does a better job with this.
104
