IDS Cisco Security Monitor Reports
I have noticed that any report that I run does NOT report ALL alarms listed in the event viewer. Has anyone else seen this? I have removed and re-added the sensor and re-checked all my settings, everything looks ok.
Thanks!
Re: IDS Cisco Security Monitor Reports
Hi ,
While generating reports , "High" , "Medium" event severities will be selected by default.
So you will see events with severity "Medium" , "High" in the generated report.
If one wants to see all alarms from the sensor(s) , either all event severities or none should be selected while generating the report.
Nagaraju Y.
I failed to mention the details of what options I chose:
I selected all on every option. All data, all time, all signitures, all alarms (info on up).
A for instance would be that the default SA password alarm was visible in the event viewer but does not show up in reports that I run.
FYI:
This is a bug in the software. The work-around is to NOT select the signature or types of signature. Leave them blank. You can choose the sensor and the level of alarm (low, medium...).
96
