IDS Deamon down
My Sensor's deamons are goinig down frequently and can't be restarted by CSPM automatically. I see error, like this:
errors.postoffice
02/21/2003 14:26:45UTC E NrProcMgrServer::startProcess daemon is still running - do not start
02/21/2003 14:27:16UTC E WgcSema can't get value of semaphore '/usr/nr/tmp/queues/fileXferd.414/bufSema': Invalid argument
02/20/2003 12:10:07UTC W WARNING suppressed while parsing global parameter
02/20/2003 12:10:20UTC E Traffic flow has started for fastethernet1 interface.
some of the "down" deamons goes up itself, but not always! I've got a 4235 S40 (latest version) and CSPM2.3.3i, SPAN interface on a C5K.
Any advice?
Silver
Re: IDS Deamon down
I have a couple of suggestions. Have you gone in for an upgrade recently? If yes, make sure that you upgarded the director too. That is necessary so that the director can recognise the new signatures. Also, at times daemon start behaving strangely (including going down) when system clock is changed and might be the source of your problem.
Re: IDS Deamon down
Thank you for the answer,
Yes, this is a brand new Sensor, and I've ugraded to the latest version both the Sensor and the CSPM.
What do you mean whit the system clock change issue? That is a problem, to set the correct time in the Sensor. However I've set the Time Zone, and the time It is different, than the time in the Event Viewer!
90
