IDS Security Monitor not running reports (VMS 2.1.1)
Recently, my IDS Security Monitor server has stopped running crucial reports. I have attempted to even run the most basic of reports that contain little data and querying. Is there anything that I can check?
Re: IDS Security Monitor not running reports (VMS 2.1.1)
Maybe you want to clean up some event entries from the database and then run a backup to reclaim the disk space used by the idsmdc.log file.
Cleanup utility is idspruning.exe.... details below;
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/vpnman/vms_2_1/secmon11/ug/appa.htm
After cleanup, on the VMS server, VPN/Security MgmtSoln--> Administration---> CommonServices--> Backup Database.
Now try running the reports.
yatin
Thanks for the information. I want to make sure that I'm doing this right:
I have deleted the millions of alerts that I do not need through the VMS SecMon Event Viewer, now I run 'idspruning -r"alerts" -p'.
Does that sound right?
Yes Coby. I'll do the
idspruning -r"syslog" -p ===> if necessary
then run the backup from the VPN/Sec Management Soln-->--> Administration---> CommonServices--> Backup Database
and then run the reports.
yatin
89
