IDS Sensor clock display inconsistencies?
Hi all,
not sure if anyone has come accross this one before. When I log onto my IDS Sensors via SSH using a standard account the "show clock" command gives me a response one hour earlier than it should. The sensor is configured to use NTP and I suspected the problem is with the daylight savings summertime parameters.
However, this is where it gets a little perplexing: when I log into the sensor using the service account (Linux OS), the system time appears to be correct.
I've tried taking the ntp server out of the equation with little success. What tends to happen is that when I enter a time maunually, it sill subtracts an hour? (for example I enter 14:00 and "show clock" tells me the time is 13:00) The impression I'm getting is that the sensor is not parsing the daylight savings parameters correctly.
Another question in relation to this is whether the Zone name and DST Zone names are of any significance or are they simply naming variables? We're located in Sydney, Australia, so I've smply put down AEST for both. Thanks in advance.
1 ACCEPTED SOLUTION
Re: IDS Sensor clock display inconsistencies?
There is a cisco ddts bug written against this problem:
CSCed61826 - IDS summer time / dst show incorrect for southern hemisphere zone
description:
If you setup summertime (spanning the new year) and
your current time is within the summertime period AND past jan 1st, then
the summertime start/stop times are mistakenly calculated for the following
summertime (the next year).
Please see below the result
of show clock det before reboot and after reboot.
Before reset :
4215-1# sh clock det
*12:53:01 AEDST Sun Feb 01 2004
No time source
Summer time starts 03:00:00 AEDST Sun Oct 05 2003
Summer time stops 01:00:00 AEST Tue Mar 30 2004
After reset, and IDS comes up :
*01:55:53 UTC Sun Feb 01 2004
No time source
Summer time starts 03:00:00 AEDST Sun Oct 03 2004
Summer time stops 01:00:00 AEST Mon Mar 28 2005
(SEE here that it is showing AEST instead of AEDST, and it would seem
to be because the summer time start and stop has moved to the new year
2004 and 2005 already, instead of the supposed 2003 to 2004 still)
*11:56:27 AEST Sun Feb 01 2004
No time source
(For this to be corrected I have to make the system get the sorrect
summert time start and stop years 2003 and 2004, then it would get
february correct again to AEDST)
4215-1# clock set 13:18:00 November 1 2003
*12:18:02 AEST Sat Nov 01 2003
No time source
4215-1# clock set 13:18:00 February 3 2004
*13:18:01 AEDST Tue Feb 03 2004
No time source
4215-1#
Further, if I then play around with clock such that I make it November
2004, then the summer time moves to 2004-2005 again, and if I go back
to February, then it would show as AEST again, not AEDST.
4215-1# clock set 13:18:00 November 1 2004
*12:18:03 AEST Mon Nov 01 2004
No time source
*12:18:02 AEST Tue Feb 03 2004
No time source
4215-1#
workaround:
If you setup summertime (spanning the new year) and your current time is within the summertime
period AND past jan 1st, then the summertime start/stop times are mistakenly calculated for the
following summertime (the next year).
In Australia, summer time start is Oct, and stop on March.
For February 2004, it should now be summer time "AEDST" Tue Feb 03 2004.
The show clock detail should have something close to
Summer time stops 01:00:00 AEST Tue Mar 30 2004.
However, if the show clock detail shows the coming years summer time :
Then February would not show the correct time
"AEST" Tue Feb 03 2004
We can try to correct the time infomration by temporarily going a year back and within the summer
time period, then correct the time again.
eg :
No time source
*13:18:01 "AEDST" Tue Feb 03 2004
No time source
Please execute a "show conf" and paste the output for the section showing the configuration of the timezone and summertime settings.
I can take a quick look to see if the configuration may be wrong, and also try it here in our lab.
description:
Before reset :
No time source
No time source
No time source
No time source
No time source
4215-1#
No time source
No time source
4215-1#
workaround:
eg :
No time source
No time source
Thanks for the replies guys. Full marks go to James for the resolution.
The following lines did the trick:
# show clock detail
*12:18:00 AEST Sat Nov 01 2003
No time source
Summer time starts 03:00:00 AEST Sun Oct 26 2003
Summer time stops 02:00:00 AEST Tue Mar 30 2004
# clock set 10:05:00 March 10 2004
# show clock detail
*10:05:01 AEDST Wed Mar 10 2004
No time source
Incidentally, I notice in your example James that you are set to change daylight savings time on Sun Oct 05 2003. From my understanding the cutover for Australian daylight savings is the last Sunday of October - that is, assuming you're in Australia ;)
Cheers.
BTW, any idea on whether or not this issue is going to be resolved or has been resolved by any of the Sensor updates? Having to do this manually to 9 sensors plus incorporating NTP anytime we perform any time changes during daylight savings can get to be a bit of a pain.
A fix has been checked into our code base and is slated for the CIDS 5.0 release (you can contact the cisco TAC and request an earlier release).
225
