IDS signurature update problem
Hello
when I enter the command
"upgrade ftp://(ftp server IP )/IDS-K9-sp-4.0-2-S42.rpm.pkg"
and key the right user account and password
then the ids show the follow message
Error: download file does not exist: /usr/cids/idsRoot/var/updates/IDS-K9-sp-4.0-2-S42.rpm.pkg
I do not understand what the message mean ?
Silver
Re: IDS signurature update problem
The error message is not quite clear (slightly misleading), but seems like sensor is looking for the /IDS-K9-sp-4.0-2-S42.rpm.pkg file and unable to find it. Please check your ftp server setting (default directory) and see if its setup correctly and if the file is there.
Mynul
There are some known bugs with ftp updates (fixed in 4.1). Here are some workarounds:
- use scp or http as the file copy protocol
- create a service account, manually ftp the update file to the sensor, then issue
a cli ftp update command with the sensor's ip and the service account name
87
