IDS - TCP reset for signature
I have a IDS 4210 and running version 3.1.I am not able to configure tcp reset for string signature or ftp connections.
Please advise/help
1 REPLY
Silver
Re: IDS - TCP reset for signature
First you need to make sure that sensor is seeing those signatures (may be snoop would help).
Next you check if the packetd.conf file shows you that this/these particular signatures are set for TCP reset.
Nadeem
96
