IDSM BLADE DOES NOT want to start services
Using 485679104 out of 4211310592 bytes of available disk space
Sensor version is : 3.0(4)S20
I'm having problems with one of my IDSM blades. It does not want to start its services. The configuration is correct , and this is the only IDSM blade that I'm having this problem. Is there a way I can start these services manually? I've tried rebooting/resetting the blade and the problem persists.
xxxxxx(diag)#nrconns
Error timeout waiting to register with postoffice.
Sensor application status:
nr.postofficed not running
nr.fileXferd not running
nr.loggerd not running
nr.packetd not running
nr.sapd not running
Configuration last modified Wed Jul 17 12:39:23 2002
Re: IDSM BLADE DOES NOT want to start services
I'm experiencing the same problem. Have opened a TAC Case and am waiting for resolution. Engineer assigned to case suggested resetting the blade (done that - just as you have), still no luck. Waiting again!
Will pass on resolution (if there is one) soon as I get one.
Goodluck!!!
The DDTS Issue: CSCdy07658 was created a few weeks ago for just this issue.
Previously we had seen it only once in our test lab, and at one customer site.
It appears to now be at both of your sites as well.
Our development team has not been able to determine the cause as of yet.
In both cases we knew of, a re-image of the application partition was necessary to get the sensor back up and working again.
Please contact the TAC and have them link your case to CSCdy07658, then re-image your IDSM and load the latest 3.0(4)S20 Service Pack and see if the problem goes away. If the problem persists after re-image then please contact the TAC and request develpment assistance.
I also was having the same issue (RE: Cisco TAC Case #C944762). I resolved the issue by moving the blade to another slot. The processes started back up immediately upon restarting. This did require re-doing the VACLs (or port spanning), and is only a viable option if you have an open slot.
After I re-imaged the blade the services started normally.
90
