You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
IDSM2 and Catalyst 6006
Does anybody know if IDSM2 works in Cat 6006 with Sup2A+MSFC2 ?
With correct sw of course.
Mladen
  • Other Security Subjects
Re: IDSM2 and Catalyst 6006
Yes, it will work.
Catalyst Supervisor Software Requirements
Catalyst OS 7.5(1) (minimum)
Native Cisco IOS Software Release12.1(19)E
Catalyst Supervisor Hardware Options with IDSM-2
With Catalyst OS 7.5.(1): Supervisor Engine 1A
* Supervisor Engine 1A/PFC2
* Supervisor Engine 1A/MSFC1
* Supervisor Engine 1A/MSFC2
* Supervisor Engine 2
* Supervisor Engine 2/MSFC2
With Native Cisco IOS Software Release 12.1(19)E:
yatin
Please let me know
Does IDS module of 6500 series comes with IDS Manager for free or it Requires a special purchase of 6500 VMS2.2 ?
The IDSM-2 runs the same version 4.x software as the standalone IDS-4200 appliances.
There are management options for both configuration and alarm viewing, you will need one of each.
No additional cost options -
(Targeted towards small 1 to 5 sensor deployments)
1) IDM (IDS Device Manager) for configuration
2) IEV (Intrusion Detection Event Viewer) for alarm viewing
3) CTR (Cisco Threat Response) for alarm viewing, and will also help determine if the attacks were successful or unsuccessful
Additional cost options -
(Targeted towards larger enterprise deployments, and contains features not in the no additional cost options)
1) VMS (Cisco Works VPN and Security Management Solution) which contains
IDS MC (IDS Management Center) for configuration of sensors, and
SecMon (Security Monitoring Center) for viewing of IDS alarms as well as Pix syslogs and generating reports.
(NOTE: VMS also contains other utilities for managing other types of Cisco security devices)
2) SIMS (Cisco Works Security Information Management Solution) for alarm viewing, provides more options for archiving and reporting as well as building a management heirarchy.
Note: The original IDSM-1 is being End Of Saled so purchase the newer IDSM-2
118
