07-08-2003 06:22 AM - edited 03-09-2019 03:56 AM
I've read several posts now referencing the use of IDSMC version 2.2. BUT....where do you get the udate? I've searched "All of Cisco" and get no results.
Can someone provide me a link to get the update?
I'd appreciate it.
07-08-2003 06:50 AM
Hi Robert,
On the below url, choose the link " CiscoWorks VPN/Security Management Solution 90-day Evaluation Software"
http://www.cisco.com/kobayashi/sw-center/sw-cw2000.shtml
Fill in the form, click on the Encryption warning/info and you will get there.
Its a single file of 500MB or so and has all the MCs
yatin
07-08-2003 07:02 AM
yatin....this is for a 90 trail subscription. I already have a licensed copy of VMS 1.1. Where can I download a full/update version of VMS 2.2?
Thanks!
07-08-2003 07:05 AM
Robert,
The 90-day Eval is the full version. You can import the VMS2.1 license during the VMS2.2 install and you are all set. After loading up this license, the VMS2.2 won't be a 90-day eval anymore.
yatin
10-17-2003 05:17 AM
Hi Yatin,
We bought VMS 2.1, and I dowloaded VMS 2.2. I did not upgraded from 2.1 to 2.2, just installed 2.2 directly. How can I import the license files from 2.1 CDs to 2.2? thanks a lot.
David
01-05-2004 02:04 PM
Did you ever get an answer to this question?
"We bought VMS 2.1, and I dowloaded VMS 2.2. I did not upgraded from 2.1 to 2.2, just installed 2.2 directly. How can I import the license files from 2.1 CDs to 2.2? thanks a lot. "
I find myself in the same situation.
My 90 license just went out at the end of Dec 2003.
I can't seem to find instructions on updating a license. All of the information talks about being prompted for a license on install...
Thanks for anyinfo you might have...
gary price
10-17-2003 10:12 PM
I downloaded the all-4 files and then try to extract them using the first file called eval-vmmc-v22-w2k-k9.zip. It prompts for the second file.
The extraction fails with the message
Extracting to "C:\tftpboot\temp\"
Use Path: yes Overlay Files: no
Error in file #1: bad Zip file offset (Error local header signature not found): disk #1 offset: 4
I checked the file size against the files on the web and they are identical. What am I doing wrong?
10-20-2003 12:43 AM
I had the same problem. After an update to WinZip v8.1 I could extract the Zip-Files.
07-08-2003 07:02 AM
If you have VMS 2.1 and an SAS contract. You can go to the product uprade tool located in the SW center and order the upgrade.
10-28-2003 12:46 PM
The product upgrade tool can be accessed with a valid account at the following URL: http://tools.cisco.com/gct/Upgrade/jsp/index.jsp
I had to go through my support provider to order the VMS2.2 upgrade, but you will get the entire package with a valid SAS support contract on VMS. I like to have the CD's for DR.
