ifconfig -a doesn't show the second interface?
Hello all, I'm trying to figure out where someone plugged our sensor's monitoring interface in so I can span the port. Unfortunately no one described the interface and I can't find any docs with that info. So I figured I could grab the MAC address from the box, then find it in the switch's mac table (if it is there, which I'm not at all sure it is). But when I do an ifconfig -a I get:
lo0: flags=1000849<UP,LOOPBACK,RUNNING,MULTICAST,IPv4> mtu 8232 index 1
inet 127.0.0.1 netmask ff000000
iprb0: flags=1000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4> mtu 1500 index 2
inet 10.1.1.1 netmask ffffff80 broadcast 10.1.1.1
ether 0:90:27:73:12:d5
Does anyone know how I can get info on the monitoring interface? And why was this functionality taken out? Security? (or is my sensor simply not finding the NIC?)
1 REPLY
Re: ifconfig -a doesn't show the second interface?
ifconfig -a only shows "plumbed" interfaces. We deliberately do not plumb the sensing interface for security reasons (which you proved being unable to find it) You could plumb the interface temporarily, get the info you need then unplumb it.
377
