IIS and SCEP configuration
I install Microsoft Certificate server
and SCEP (mscep.dll)
If i try to connect via the web on
http://URL/certsrv/mscep/mscep.dll
Than IIS ask for username, password and DOMAIN name.
If I Enter here username and password of anyone of the registered users on this computer ( I mean on the Certificate server )
Than I get normal result .
Than I going to settings of the IIS server and set the next : No need to use local authorization for runnig mscep.dll
and then go to http://URL/certsrv/mscep/mscep.dll
So .. I see blank page .
I need to use http://URL/certsrv/mscep/mscep.dll
without authorization . Could you say me some solutions or maybe some documents to solve this problem .
My system is
WIN2K server, Servicepack 2,
1 REPLY
Anonymous
N/A
Re: IIS and SCEP configuration
You have to disable authentication under IIS server
once you have that disabled, your Cisco devices would be able to get the certificates using SCEP
make sure that you enable computer management under MMC, and enable anonymous access for the IIS server
160
