03-11-2004 04:49 AM - edited 02-21-2020 01:04 PM
IF you configure a LAN-to-LAN connection somewher in the middel you have the option to set the IKE proposal.
The drop down box doens't display all the IKE proposals active in the SYSTEM-TUNNELING PROTOCOLS-IPSEC-IKE PROPOSALS.
When you read the help file, you should be able to select all the active IKE proposals.
I thus can only configure a specific IKE propsal for a LAN-to-LAN connection in the SYSTEM-POLICY MANAGEMENT-TRAFFIC MANAGEMENT-SAs.
Is this a bug or ???
03-17-2004 09:07 AM
Some times your tunnel may not come up if your IKE proposal is in the "Inactive Proposals" list. To configure the active IKE Proposal select Configuration > System > Tunneling Protocols > IPSec > IKE Proposals . If your IKE proposal is in the "Inactive Proposals" list you can enable it by selecting the IKE proposal. For a better idea check out the following document,
03-17-2004 11:38 PM
I meant that not ALL the active IKE proposals are shown in the interface !
