Inside access problem
I have a firewall in place that i just put in. Everything is working fine except for one thing. Our file server which IP address is 206.x.74.10 can't be accessed from our tech that our also inside the firewall. They can get out fine to the internet, access other servers behind and outside the firewall but for some reason they cant access that one, which happens to be our file server, pretty important for them to be able to get there. below is a cope of my config, any suggestions would be greatly appreciated.
thanks
mike
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security10
nameif ethernet3 intf3 security15
nameif ethernet4 intf4 security20
nameif ethernet5 intf5 security25
enable password xxxxxencrypted
passwd xxxxxx encrypted
hostname pixfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list inbound permit icmp any any echo
access-list inbound permit icmp any any echo-reply
access-list inbound permit tcp any host 206.x.208.8 eq www
access-list inbound permit tcp any host 206.x.208.8 eq 443
access-list inbound permit tcp any host 206.x.208.8 eq ftp
access-list inbound permit tcp any host 206.x.208.8 eq domain
access-list inbound permit tcp any host 206.x.208.8 eq 799
access-list inbound permit udp any host 206.x.208.8 eq domain
access-list inbound permit udp any host 206.x.208.8 eq snmp
access-list inbound permit tcp any host 206.x.74.3 eq www
access-list inbound permit tcp any host 206.x.74.3 eq 443
access-list inbound permit tcp any host 206.x.74.3 eq ftp
access-list inbound permit tcp any host 206.x.74.3 eq 5800
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
interface ethernet3 auto shutdown
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
mtu outside 1500
mtu inside 1500
mtu intf2 1500
mtu intf3 1500
mtu intf4 1500
mtu intf5 1500
ip address outside 10.10.10.2 255.255.255.0
ip address inside 206.x.74.1 255.255.255.0
ip address intf2 127.0.0.1 255.255.255.255
ip address intf3 127.0.0.1 255.255.255.255
ip address intf4 127.0.0.1 255.255.255.255
ip address intf5 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
failover ip address intf2 0.0.0.0
failover ip address intf3 0.0.0.0
failover ip address intf4 0.0.0.0
failover ip address intf5 0.0.0.0
pdm history enable
arp timeout 14400
nat (inside) 0 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 206.x.74.5 206.187.74.5 netmask 255.255.255.255 0 0
static (inside,outside) 206.x.74.3 206.187.74.3 netmask 255.255.255.255 0 0
static (inside,outside) 206.x.74.6 206.187.74.6 netmask 255.255.255.255 0 0
static (inside,outside) 206.x.208.8 206.187.208.8 netmask 255.255.255.255 0 0
static (inside,outside) 206.x.208.2 206.187.208.2 netmask 255.255.255.255 0 0
static (inside,outside) 206.x.208.7 206.187.208.7 netmask 255.255.255.255 0 0
static (inside,outside) 206.x.208.12 206.187.208.12 netmask 255.255.255.255 0
access-group inbound in interface outside
route outside 0.0.0.0 0.0.0.0 10.10.10.1 1
route inside 206.x.208.0 255.255.255.0 206.x.74.5 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:xxxxx: end
[OK]
pixfirewall(config)#
Silver
Re: Inside access problem
Can the "tech" get to other hosts on the same subnet as the file server? Is the "tech" on the same subnet as the file server?
Silver
Doesn't seem to be a firewall issue. Whats the net and the subnet mask of the tech subnet? Thanks,
Mynul
The net and subnet of the office is: 206.x.208.0 with a class C subnet.
fortunately we have decided that is wasnt the firewall causing the problem.
unfortunately they have decided to take it out and now i have to reconfigure it to be used on the other side with a different backbone we have. thanks for all the help though.
mike
Gold
Hi -
I would agree with mynul that I don't think this is related to the firewall, can you post your route inside on the firewall and also the inside route for your inside gateway router - but pls remember to change ALL IP's and password's etc..
Thanks -
97
