inside to outside idle telnet session drop
greetings,
i have been given report that idle telnet session have been dropping out since i moved devices behind the PIX. Are there any issues i should be aware of in regards to PIX IOS v 6.1(1)
Hardware PIX 515
Is there a time out set for tcp sessions. i am using NAT on the inside. Is there a set time limit for leased IP's? if so how may i change this.
TIA
-j
1 REPLY
Re: inside to outside idle telnet session drop
you can use "timeout" command on the PIX to tweak the default settings;
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/cmdref/tz.htm#xtocid4
default timeout for xlate (a translation) is 3 hours
default idle timeout before a connection slot is freed is 1 hour
Hope that helps
R/Yusuf
294
