Bronze
Inside to Outside Port Translation
Is it possible to allow an Inside to Outside TCP Port number to use a specific IP address. We are having some mail issues when send mail when reverse DNS is performed and matched with out MX records.
1 REPLY
Re: Inside to Outside Port Translation
Yes you can define a second NAT and GLOBAL to do that.
example:
nat (inside)2 MailServerPrivateIP 255.255.255.255
global (outside) 2 MailServerPub-MX-IP
# Reset the translation table, this will reset all sessions !
clear xlate
or you could use a Static NAT
See:Establishing Connectivity
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a0080172786.html
Command Reference:
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_chapter09186a00801727ab.html#wp1032129
sincerely
Patrick
89
