Installation of two separate Cisco VPN clients
I am trying to install two separate VPN clients on to one machine. The problem I've had is one destroys the other upon the second install. Any ideas on how I can do install both clients on the same machine and have them work? They do not have to work simultaneously. Thanks.
Gavin
Silver
Re: Installation of two separate Cisco VPN clients
Why are you trying to do this? I doubt this is a supported config - every client I have used that I can recall will detect the other cisco client install, and provide the option to uninstall it, etc
I am doing this because we have been asked to use the customized VPN clients provided by our customers.
Silver
There isn't much they can customize - they can change the graphics and icons, but functionally there isn't a ton they can change. I would try installing their client their way, and then seeing if you can create a connection profile that allows you to connect to your vpn - you should be able to. Getting 2 versions to coexist is probably an impossibility
101
