Interface ethernet0 auto Shutdown
farhan
I have this ethernet0 interface shutdown. How do I say no shut for it?
Thanks for your help
tcross3
type;
interface ethernet0 auto
or
interface ethernet0 100full
jmia
Level 7
Level 7
Try - no shut down interface e0
Rem - need to be in config mode on e0.
Jay
rajesh_rsinghai
router#int e0
(router-config)#Ip address *.*.*.* *.*.*.*
(router-config)#no shutdown
Rajesh Jain
navinquadros
Hello Farhan,
This seems to be a generic problem. If I understand your problem correctly, you have a Ethernet port that is currently shutdown.
If this is correct, go ahead as follows:
1. Login to the router using a console cable [If that is the only ethernet port then you won't be able to telnet to it :-) ]. Get to privileged mode.
2. Type at prompt the following sequence:
a) config terminal
b) interface e0
c) ip address ***.***.***.***
# This step only if you have not configured the ip address for this port
d) no shutdown
e) exit
# exit out of config mode
f) copy running-config startup-config
# This command if you do not want to repeat this procedure the next time the router is restarted :)
g) exit
Tell me if this solves your problem and if you have any other queries
Have a nice day,
Navin
